I installed a new battery last night. The mini Yuasa YTZ7-S.
It is the same battery that CycleCat requires for their slider kit installation on (some?) Superbikes. I know Alex uses and recommends this battery also.
Two benefits that I can tell. The first is obvious: the thing is small and lightweight at 4.6 lbs. vs. 7.6 lbs. for the recommended Yuasa YT12B-BS.
The second, and perhaps most important, the YTZ7-S battery is filled, sealed, and charged AT THE FACTORY. The YT12B-BS is none of these. With the YT12B-BS, all three are done by the dealer or end user, are VERY critical to be done correctly, and increase the potential for leakage if even one is not done properly.
While the overall capacity for the mini Yuasa is only 60% of its big brother, the CCA are roughly the same. I've only had a chance to try starting the bike a couple times, but the bike fired right up. The starter sounded the same, and didn't sound like it was laboring at all while cranking the engine. The installation was pretty straight forward, with the exception being that the ground cable needed to be lengthened about 5-6 inches.
Anyhow, thought I'd be the group Guina-Pig. I'll be riding all weekend, so will have a chance to better test it.
http://www.yuasabatteries.com/battery.asp?bID=B175&vID=1701
Battery Family: YTZ Factory Activated, Maintenance Free
