I have 2011 796 I’m trying to figure and solve my headlight issue when the bike ignition is on or running headlight don’t come on unless I pull the passing light switch then the headlight turns on and the blue high beam light turns on I replace left and switch inspect headlight wire at connect within 2 inches spray with connector cleaner I don’t what else to check
