SO I'm trying to determine what brake levers are interchangable with my Sister's 1996 M900. Searching the archives got me some basics, but I need a bit more.
Given Stock Coffin style MCs, 1996 M900
A) is the brake lever a big diameter pivot pin?
B) What other motos use the same pin / MC arrangement?
C) Are there adjustable levers that will work in place of the stock non adjustable?
D) Can someone post a picture of the Big pin vs small pin differences?
Thanks,
Richard
Here ya go, the top one is a "bent" stock lever ($21.98) which are currently on back order from Ducati.
The second one is a "cheap" aftermarket adjustable ($23.95) but this one in particular did not fit properly and we have seen this more than once....we no longer stock them because of this.
Third one from the top is a OEM adjustable ($59.00) which works great
Bottom one is a CRG adjustable ($109.99) in stock
You will notice the pivot hole on each lever is large hence the "big pivot" designation
Hope this helps clarify the mystery :)
Please call us if you any more questions or would like to get a set coming your way !
KTM, Guzzi, Aprilia among many.
