There is some adjustment that can be made with the seat latch cable or in some cases shimming the lock a bit higher is needed to correct it. Pretty easy fix...
As far as a tank price goes, I can check tomorrow but I would bet a dark tank is over $1400 MSRP.. Do you need a new tank ? You can find a few on e bay and most likely on this board..
Hope this helps..
