My latest project converting a 2008 Ducati 848 Superbike into a Monster.
It started off pearl white with a few aftermarket parts. I took it down to an engine and frame, everything else was removed, everything.
I made a custom frame for an old Yamaha SR400 café racer seat. I designed the frame to match the characteristic Ducati trellis X-frame. Cut into the custom seat frame is the break light with integrated turn signals.
The headlight I used is from an older Ducati Monster. The exhaust is a custom modified QD ExBox from a Monster. Off-road tires are for the roads and trails in Panama.
The fuel tank was replaced with an aluminum tank and painted a Satin Ducati Red and finished off with vintage DUCATI decals.
The clutch cover was replaced with one that is transparent so you can see the clutch spinning, I like to see all the moving parts.
Many more modifications where made, and many parts removed. Total weight reduction was 51 pounds, along with a lower center of gravity.
Nicely done! The trellis seat support blends perfectly - that took a lot of work...not to mention the integrated tail light!
Exhaust and tire selection are cool too.
Discussion Starter #5
It wants to go fast, but I changed the throttle with a throttle tamer so it's not so sensitive. I ride it in Panama, where I now live.
