1 - 18 of 18 Posts
Cut, remove, powdercoat and..you have a ..$20 pair of rearsets...
I don't need the back pegs any longer since I have the MTS for pillion rides. I also don't have $500 or $600 for a shiny new billet set.
Looks real nice from further away, almost professional...
way to go.....cheep ass.
you just put some starving Indonesian kid who makes rearsets out of business.....
no plate of slop for him tonight.
I hope you sleep well tonight :mad:
;D
Nice job!
;D
Nice job!
it's not cause I don't want them, it's because I buy **** like this for my on going MTS project...
I lorv the mod motogpfan!! [thumbsup] Infact I like it so much I might just convert my monsta to a mono and do what you did! - Chris
ps, as for the starving kid ive sent him some travel credits so he can go to the US and beat on you...
I made these plates to rearset stock footpegs some years ago:
Looked like this applied:
The reason was that I had low slip ons and needed the holder of them and still wanting better ground clearance.
Worked real well until I made my own rearsets.
bigiain said:
Nice! That's what, about 3mm sheet Al? I assume that bottom one is flat? And that you used nuts behind them rather than tapping the Al sheet?
big
I used 3 mm stainless sheet metal on the upper plate and 5 mm s/s steel plates on the lower bracket.
The reason for choise of material was mainly because I hade those pieces laying around...
Upper plates where bolted with nuts behind and in the lower pates I made threads in the plate.
1 - 18 of 18 Posts
