1 - 20 of 27 Posts
question...I rode the bike to work today.... and noticed it's first oil leak. I'm at work and don't have the proper tools to check out the cause, but it appears to be coming from the shaft the front sprocket is attached to. Is this common, and is this an easy (just replace a gasket fix), or maybe more?
it's an 01 m900
It is more likely either a leaky clutch slave, or oil leaking past the o-rings on the shaft that the clutch slave pushes.
maybe it's nothing, buuuuut your chain's not too tight, is it? maybe pull the front sprocket when you get home and make sure the countershaft turns smoothly by hand? good luck and here's hoping it's only a seal and not a bearing problem.
is the fix.....pull the rod and replace the o-rings...or is ther a lil more to it? When I replaced my pressure plate, I had to remove and reuse the bearing, and to do that, I had to pull the rod out. I probably damaged the o-rings then :-\
the chain is a lil loose if anything
If you didn't clean the pushrod before you pulled it through you're probably right. There is a tiny oil seal on the clutch end you might want to check while you're in there.
coolness.... I'm gonna order the seals, before I check it. I might as well replace them while in in there checking.
Get yourself some sturdy pick tools to dig stuff out of the internal grooves.
Discussion Starter · #9 ·
should I pull the slave off, and clean and replace it from that side or pull the rod out from the other side?
(yes...I know not what I'm doing ;))
Whichever is easier. I think the clutch end has an actual oil seal with o-rings on the slave end. I would do it from the clutch end so I didn't damage the lip of the seal. If there are o-rings at both ends it doesn't matter.
Clean the pushrod with some crocus cloth or sand paper to remove any burrs etc. and put a light coat of grease on the rod to lube the seals/o-rings.
And whatever you do ask for help before you do anything that might be considered "stoopit". ;D
Discussion Starter · #11 ·
I wake up doing stooooopid things ;)
I know, I know..........................lm told me.
maybe this isn't what's up with your bike but check anyway. my gsx-r was 'leaking' oil at the counter shaft and i was going crazy wondering how i would fix it. so i cleaned the hell out of it and discovered it was just chain lube getting hot against the case and dripping off. sure glad i cleaned it before i ripped the bike apart. that would've sucked.
Discussion Starter · #14 ·
I lube the chain.... but not that much ;D
LT Snyder at desmotimes sells the o-rings as a little kit, and includes the one that goes on the end, which you have to do from the clutch side, so that's what I did. But, he's got a $30 min order, so you got to find something else to buy from him at the same time.
Discussion Starter · #17 ·
What sucks is.... I just ordered Honda parts for the scooter from bikebandit the other day...and had I waited... I could have ordered the o-rings at the same time.... the individual parts are less than two buck :-\
Oh well
Discussion Starter · #19 ·
howie said:
Oh, since no one mentioned it do make sure it is not a leaking slave. The brake fluid can mix with the flung chain lube and look like engine oil.
Thanks.... I'll check that too.
Buy his book that shows how to do it - $30, too
1 - 20 of 27 Posts
