Psssst... hint is to disconnect the blinkers. Just unplug it from you point of preference.
The tail light cover off a <gulp> buell will fit the Monster housing. And, it comes with a clear window on the bottom to shine on the plate. They're actually manufactured by the same company (Italian).zooom said:zip a lil hole in the bottom of the tailite lens so it shines onto the plate and insert a piece of plastic or something to keep debris from getting in there and you should be golden!....I know there are some manufacturers out there who use a clear bottom of the tailite to illuminate the tag!
I haven't found one that has the motorcycle stickers.monarc said:take it to a gas station, not a motorcycle shop. i've usually never had a problem...
i wasn't trying to get around anything. Just posting my experience. I figured the brake light was enough to light the plate. And also, I never knew there was a reflector requirment or that the blinkers had to be 9 inches apart.jwbowen said:Sorry to rain on the endless parade of ways to get around inspection problems, but consider the following:
My comments were not directed at you personally. Sorry if it didn't come out that way. Your initial post clearly suggests an interest in doing it right and letting the rest of us know what happened to you and why.Narflar said:i wasn't trying to get around anything. Just posting my experience. I figured the brake light was enough to light the plate. And also, I never knew there was a reflector requirment or that the blinkers had to be 9 inches apart.
Ya, I got a lot of questions for them. What pisses me off is that I didn't even get a chance to talk with the inspector. Now I got a failed sticker when at least one of the items could have been fixed on the spot. I can't prove it and I really don't want to dig but I bet he said I needed reflectors because my blinkers were in violation. They said I would have passed if I had the reflectors and plate lights even though the blinkers were an obvious violation that they made a point to make me a aware of.jwbowen said:My comments were not directed at you personally. Sorry if it didn't come out that way. Your initial post clearly suggests an interest in doing it right and letting the rest of us know what happened to you and why.
If it were me, prior to the next inspection I'd ask the inspector where the requirement for reflectors comes from -- in a non-aggressive way, of course. Maybe I missed something in the regs, or it's a brand-new requirement, or something else. That would be good for all of us to know.
