Looking for help. My 2000 M750 Parking Lights and Dash Indicator "Green" Lamp are always ON (Start and Run Position). This just started after winter hibernation. I installed a new battery and had the dealership replace the throttle cable recently. I took it back to the dealership and they said everything checked out okay in the key switch wiring. They wanted extra money to check/troubleshoot the Instument Panel. I said no. I've checked the wiring harness connectors/wires from the tank back to the tail lights and everything seemed fine. Anyone have any ideas? Thanks much.
Discussion Starter · #2 ·
Today I looked at the wiring schematic (yellow is the wire), inspected and ohm'd every wire, connector, display, parking lamp, ignition switch, and everything checked out okay. I'm stumped!
