1 - 12 of 12 Posts
these parts are from theft recovery/vandalism bike, a got for parts for another project...these are leftovers...
Rear rim w/sprocket & rotor.....$125
Forks (no triples)...................$250
Swingarm w/pivot bolt.............$50
Rear axle...............................$25
Rear shock w/rod....................$50
Rear caliper w/master..............$40
Front calipers w/master, lines...$125
Airbox...................................$25
Clutch master w/lever & SS line..$40
Clutch Slave cyl.......................$35
Wiring harness.........................$50
Front fender (no cracks or missing pcs.) rub mark on top.....$25
hardware (nuts & bolts, including engine mounting bolts)..............$15
Left rotor................................$75
Coils.......................................$25
Voltage regulator/rectifier...........$30
Fuel Pump w/extras...................$50
Right side switches....................$20
Throttle assy. w/cable................$25
Engine/motor, complete (starter, thr. bodies, clutch, sprocket) no damage to cases, engine turns over and goes thru all the gears. Gauges, ignition switch and ECU were missing and i couldn't try to start this baby. CD title says 9942 miles..................................................MAKE OFFER
Everything is + shipping, send me your e-mail for high res photos or zip for shipping quote. Taking DIBS here.
INTERNATIONAL SHIPPING IS OK!
Discussion Starter · #11 ·
UPDATED LIST...
UPDATED LIST...
s4rHoolie,
Please send pictures of the above parts to mike - @ mikeandmaryjones.org (after removing the redundant spaces and dash).
Thanks!
Mike
1 - 12 of 12 Posts
