CORSE 4 Spring Slipper Clutch w/ Surflex Plates
Sale Price: $939.99
High quality Complete Italian made Lightweight 4 Spring Slipper Clutch helps prevent rear wheel lock up on deceleration. Lighter weight, reduces rotating mass and improves throttle response. The 4 spring design has a little more travel and is much smoother than most 6 spring designs. It is a several ounces lighter as well. Includes 4 red corse springs and a complete set of high quality aluminum Surflex friction plates.
MW Drop-in Slipper clutch
Sale Price: $599.00
High quality Italian made Lightweight Slipper Clutch helps prevent rear wheel lock up on deceleration. Lighter weight, reduces rotating mass and improves throttle response. This kit is perfect for low mileage late model Ducatis from 2003+ that come with aluminum clutch baskets and aluminum plates that you can re-use
MW Ducati 848-SC-696 Wet Slipper Clutch
Sale Price: $695.00
848 Billet Slipper Clutch fits wet clutch 848, 07+ Sport Classic, M696, MTS 1100 and Hypermotard 796.
Made from 7000 series billet aluminum this kit includes everything you need except the clutch basket and plates. This clutch is designed to work with your OE clutch basket and plates.
MW Track Clutch Upgrade
Sale Price: $474.99
This is an upgrade kit for those who need a better clutch feel but don't want to upgrade to slipper clutch. This kit includes plates and billet clutch drum.
STM Evoluzione Slipper Clutch
Sale Price: $999.95
  • Utilizes a 90mm diaphragm spring
  • Diaphragm spring provides more pressure under lock up, less drag than helical spring and digressive lever engagement
  • Secondary spring is also of diaphragm construction allowing for a wider tuning range and eliminating the need for multiple ramp angles
  • Utilizes OEM clutch basket and plates
  • Utilizes titanium-nitrated Progressive Engagement Plate
  • Features a clutch inspection system
  • Pictured with 48 Tooth STM basket which is available separately.
STM SBK Slipper Clutch
Sale Price: $1,499.95
  • Utilizes a 125mm diaphragm spring to apply pressure on the outer edge of plates
  • Light clutch pull with ability to handle 200+ HP
SURFLEX Slipper Clutch w/ Plates: Red
Sale Price: $1,150.00
Complete Lightweight Slipper Clutch by Surflex . Lighter weight improves throttle response and reduces rotating mass. This clutch is preferred by many track and street riders over many more expensive models due to its smooth, low effort engagement and long wear characteristics. It is also requires the least amount of maintenance. It has the lightest clutch pull of anything onthe market.
Discussion Starter · #2 ·
More clutch parts on sale
Corse Dynamics Springs/Keepers/SS Bolts Kit
Sale Price: $42.99
Corse Dynamics has manufactured clutch springs and keepers for the Ducati clutch to perform exactly like their stock equivalent. They go one step further and polish the stainless steel springs to offer a properly functioning, attractive rust proof design.
The kit contains: 6 billet aluminum spring caps in black, clear, red, grey or gold, 6 polished stainless steel springs that won’t rust or corrode like stock springs and 6 stainless steel bolts.
OBERON Clutch Slave Cylinder 29mm
Sale Price: $129.00
Designed to improve the performance and looks of the original Ducati cylinder. Substantially reducing the heaviness of the original clutch action, aching arms and clunky gear changes are a thing of the past. The internal piston design, seals and breather hole have been drastically enhanced to stop leaks and leave a smoother clutch action. CNC machined from billet for lightness, strength and precision looks. The 29mm piston size is much easier to find neutral while still having an easy clutch pull. Everything you need is included in the kit plus a conversion shaft for earlier Ducati's.
*** Add MOTUL RBF600 Racing Brake Fluid 0.5 litre as an option when purchasing this Oberon Slave Cylinder for only $10. ($18.95 value)
MW Billet Clutch Cover: 10 Spoke
Sale Price: $119.95
Cool off and show off your dry clutch with a strong "10 spoke" billet aluminum vented clutch cover by Motowheels. Machined of a single block of 6000 series aluminum, it is strong enough to with stand most impacts. Designed and manufactured for strength, the Motowheels billet cover is not priced to break the bank.
Fits all dry clutch Ducati: 748-998, 749-999, M900-M1000, 900SS-1000SS. MS, ST, S4, S2R 1000, S4R, S4RS, MH900e,1098... Available in several colors: gold, silver, red, titanium and black
OBERON "Vortex" Clutch Cover
Sale Price: $129.00
Made from billet aluminum this clutch cover from Oberon is a great way to show off your clutch
Corse Dynamics 4 Spoke Clutch Cover
Sale Price: $139.95
Cut from a 15 pound piece of billet T6 aluminium, this cover is extremely stong while still allowing great venting
OBERON "Racing" Pressure Plate
Sale Price: $115.00
Ducati dry clutch pressure plate. Ideal where the clutch is exposed. Fitted with double shielded roller bearing.
Available in Black, gold, titanium look, purple, red and silver.
The tower plate is designed to cover the clutch springs so that in the event of a fall the spring posts are protected from damage
Ducati Clutch covers
RCM Billet Clutch Cover "Naked"
Sale Price: $119.99
Billet Clutch Cover for most late model Ducati's with a dry clutch.
RCM Billet Clutch Cover "Open Air"
Sale Price: $119.00
MD Aluminum Clutch Cover: 106
Sale Price: $59.95
Die-Cast Injected Aluminum and CNC machined for accurate fit and lightweight
CF "Closed" Clutch Cover
Sale Price: $89.96
High quality pre-preg Carbon Fiber "Closed" Clutch Cover for all dry clutch Ducati. Fits 748-998,749-999,848-1098, Monsters, Supersports, ST, Mhe, Sport Classics, HM...
MW Billet Clutch Cover: Original
Sale Price: $129.95
Made of 6000 series aluminum, it is designed with strength in mind. Fits all dry clutch Ducati: 748-998, 749-999, M900-M1000, 900SS-1000SS. MS, ST, S4, S2R 1000, S4R, S4RS, Sport Classics. MH900e, 1098... Available in several colors.
RCM Billet Clutch Cover "Grove"
Sale Price: $135.00
Billet Clutch Cover for most late model Ducati's with a dry clutch. Available in red and gold.
