Search and find,...
Found a very interesting topic on a German Forum,... (Thank you Markus)
You would need the following,....
1 x KTM shift lever7603403104433S and 1 x KTM special washer 58303061100 and a tapered M8 x 50mm bolt.(you have to drill out the hole to 8mm instead of the 6mm in the lever for the M8x50 to fit)
1 M8 (inner thread )ball joint and M8x16mm
Furthermore a 22mm diameter bushing that is 20mm long and has an 8mm hole for spacing the lever,
And a bushing (11mm diameter, 6mm long with a 6mm hole) to put behind the QS rod in the front connection.
Result, see pictures,... to me,... it looks awesome !!
