Does any one make a front wheel spacer to replace the speedometer drive for M900's? :)
G Guest · Discussion Starter · #1 · Feb 10, 2004 Does any one make a front wheel spacer to replace the speedometer drive for M900's?
Norm · Premium Member Joined Feb 17, 2005 · 5,076 Posts #2 · Feb 10, 2004 Only show this user You can just use a peice of steel or aluminum tubing. If you like, I can make you one for free, just send me your address.
G Guest · Discussion Starter · #3 · Feb 10, 2004 or you can use the spacer from in the speedo housing.
