S
s4strati
·Guest
hey gang,
browsing around on ducati.com and although i'm not in the market for either bike, i thought i'd compare the s4r with the st4s. they both the 996 motor with the same bore/stroke, 50mm throttle bodies, same gear ratios... but the st4s puts out more power across the board:
http://www.ducati.com/bikes/my2004/...13&modelName=S4R-04&part=comparison&x=17&y=13
pretty sure they run the same cams, but anybody know where the st4s gets the extra powers? different sized valves? i tend to doubt it. the exhaust? mapping? note also that the s4r has _slightly_ higher compression which would give it a theoretical advantage. anybody know the story? just wondering... maybe the s4r's exhaust is just really inefficient despite the expansion bulb in the header. hrmm...
