Any BMW motorcycle dealer will have what you need.(about AUS$80 here in Oz) A lot less than Ducati sell the whole headlight for as a complete unit. DOH!!!
Haven't you guys heard of headlight protectors?
Replacement Headlight Parts
Instead of getting a whole replacement OEM headlight assembly (around $370) if you screw up a part of the headlight, you can replace bits with BMW pieces.* The parts numbers are from a work order at the local shop, so I can't confirm they are exactly correct.**
631212356402 --* rim ($100) Edit: this part no. may not be correct. If it is not, try 63121356402.
63121358147 -- glass/Lense ($25)
63121355396 -- reflector ($95)
I'm not sure what model BMW they are off of (Edit:* I'm informed by s4grrr that the headlight bits are off an R80) and you can prolly land the parts a lot cheaper than above.* If someone knows the BMW model # or can confirm the parts nos. (I'm pretty sure they're right), shoot me a pm and I'll edit the post if necessary.
Monter Glass
Yes, confirmed, the BMW parts are the same fit, ask for R90S parts, sounds cooler, but last glass my dealer sold me was almost double that $25, maybe I should have asked for the more boring R80 glass LOL?
