When I turn the key to try and start the Monster ('99 M750, DP pipe, jet kit), the yellow relay under the seat goes "buzzzzzzz". I never get any power to lights or anything else. The battery is charged, fluid levels good. The bike is sitting in the garage, and it's about 45-ish degrees in there. I tried bringing the relay inside to warm it up first, but it's like the little relay is bouncing off the contacts and is never "sticking"... hope that makes sense. I even swapped in a brand new relay with the same results.
The fuses in the fuseblock next to the relay are all ok. Are there any others that I should check? (Sorry, I don't have a service manual yet)
