Hi folks,
This is not a new idea, but I haven't seen anyone post about this specific mod, so I thought I'd share. For a while now I have not liked the look of the bracket that supports the passenger foot-peg on the 796 and don't ever carry a passenger. After some inspiration from other posts here and on other Monster forums, I figured I'd give it a go.
This has been on my to-do list for a while, and I actually bought the spare brackets from @Atrais on this forum back in 2021!
Anyhow, the basic idea was to cut down the stock peg brackets, as so many have done, but this time to try to attach stock heel-guards. I had bought a pair of an 848 super-sport.
After looking at the options and taking a few measurements, however, it looked like they might not fit all that well. Also, it wasn't clear how I'd attach them. By chance, a colleague introduced me to the idea of brazing and after a quick search I found this:aluminum brazing rod.
So, in case anyone else is interested in a similar idea, I figured I'd share.
Here were the original brackets, actually from a 696, not a 796, but the parts are identical.
It was a very quick hacksaw job to cut them down. The cast aluminium is surprisingly soft, and cuts quite easily.
You can see that there is one large rubber bushing inserted in the bracket, which I needed to remove.
It's pushed into a machined hole that has a shoulder on the far side, so it wasn't possible to just press/beat it back out.
I used some threaded bar, and a few large washers as a home-brew puller/extractor.
Because I was essentially pulling them out by the rubber part (the outer metal ring was obscured by the shoulder on the hole) I couldn't use too much force, for fear of tearing the rubber, so I decided to apply little bit of heat with a propane torch. It didn't take much.
I then spent quite a bit of time with a regular hand-file to shape the cuts and to get the parts to fit together reasonably well.
Here is a mock-up of how I wanted it to fit:
And here it is after a brazing - you can see the original finish burned off.
After some time with a file to remove the excess bead on the joint and some time to clean the surface with a wire wheel (mounted in a drill-press), I had the finished pair:
Then a good clean with acetone and a few coats of Rustoleum High-Heat Matt Engine Enamel, and they started to look pretty OK:
Re-fit the bushings and re-attach the foot-pegs and levers, and they were ready to install:
I'll follow up with a photo of them on the bike.
Time will tell how well the engine enamel will hold up, though I have had good experience with the high-heat stuff once it's been baked.
Interested to hear peoples thoughts, or if anyone else has tried something similar.
