Hello, 2013 Monster 796, please help. While removing the fuel tank, I pulled the connectors from the fuel pump plug on the wire harness side. Does anyone know how the wires are supposed to be routed?
Greetings
Greetings
These should be the same as my 1100 EVO I just finished messing with. Can you upload a pic of the wires/plug on both sides of the connector?
You will likely need to order a Delphi weatherpak 4pin connector and the proper crimping tool to fix this right. Maybe your connector is still in good enough condition to put the pins back through though.
