See the main Parts for sale thread
All available Brisbane or freight Australia wide
Scrub that - I'll make it easy for everyone....
Used but looks NEW Ducati Performance - Monster Comfort Seat 696-796-1100
OEM part #96766909B - Was only on for 50Klms, sold bike so no longer needed - Fits M696/696 ABS, M796/796 ABS, M1100/1100 ABS, M1100S/1100S ABS - $250
Monster 696 - 2008 to 2012 – 848 Evo Showa Forks and adaptor kit
**I assume this will suit all Monsters from 2008 to 2015 plus 796/1100 as well**
INCLUDES
Almost new Pair 2011 848 Evo Showa fully adjustable forks done approx. 1200klms
696 top steering yoke machined to suit these larger 848 fork tops
Spacer shims for your original lower steering yoke to fit 848 forks
Spacer kit and longer bolts so you can use your original 696 disc’s
Spacer kit so you can use your original 696 front wheel and axle
Easy to fit with no additional modifications, can be swapped back at any time
Huge improvement in ride – New fork seals included
$750
Monster 696 -796-1100 - 2008 to 2010 – 25mm higher OEM handle bar riser OEM part off 2012 onwards models
OEM part 36011011A - You can replace your original handle bar riser with this later model riser to keep the OEM look and value, not some machined part that doesn’t match the colour and style of the other handlebar components. As new used for 3 months in box. $100
OEM adjustable Clutch and Brake levers. As new $20
Monster 696 – 796 – 1100 – OEM Seat Bag
Almost NEW Ducati Performance Rear Seat bag – inc rain cover and cover that goes over rear seat - the bag zips to the cover - See Ducati Monster Soft Trunk Bag part number 96766709B - $200
2 x almost new Ducati OEM rear mufflers with late model black heat shields 2010 model on-wards, fits 696/796/1100 - $500
1 x almost new Monster 1100 under seat Y exhaust pipe and flapper valve/cable - $50
Australian Registration laws have changed, you will need OEM pipes/mufflers to Re-register/Sell or Trade you bikes going forward
Monster 696-796 – Hypermotard 796 – New California Cycleworks Exact Fit Timing belts pair – SKU: TB696 – Free Monster 696 OEM air filter done 500klms
$75
Personal Number Plate – Queensland
SIX96 suit Ducati Monster 696 motorcycle or whatever it means to you, can redo as car/truck plate with PPP by just filling out form/fee – Red plate white letters
$750
All parts available plus freight - Sold in Australian Dollars
or Pick up Northside, Brisbane Australia
PM for photos
