Most maps, whether canned maps from DP and elsewhere or custom dyno remapping don't make any changes to the startup enrichment tables. They can still be modified, but you have to actually open up the .bin file and make the changes.
If you connect your ECU to GuzziDiag do the temperature and atmospheric pressure readings seem to be correct? As well as the TPS set at 2.7?
Although I don't doubt that it could probably be set a little bit richer across the board if you're still running the factory map with any exhaust modifications. Especially in the cooler months.
