Hello fine folks. I'm trying to swap the stock handlebars on my 1200 to cafe racer style bars. However, it seems the forks are too low to swap to clip on style bars. What other options do I have, short of replacing the forks that are taller?
I've looked into some options for a 796, with the similar thought that the triple-clamp is quite low, so clip-ons under them would be very low.Hello fine folks. I'm trying to swap the stock handlebars on my 1200 to cafe racer style bars. However, it seems the forks are too low to swap to clip on style bars. What other options do I have, short of replacing the forks that are taller?
Two options I have come across:
- bracket bolted to the top of the triple-clamp: Woodcraft Clip-On Risers
- clip-ons with a rise before the bar: Woodcraft 3 Inch Riser Clip-Ons
Of course there are plenty of options other than Woodcraft.
Actually, the stock clip-ons from some bikes might be suitable. I was looking at 50mm clip ons, maybe yours is different, but I found that ones from early some 2000s Kawa ZXR were compatible and also offered a decent rise. One thing to watch out for is the fluid reservoir (brake/clutch) as the stock ones are pretty big and may not fit well on clip-ons.
Another thing to think about is whether the clip-on is split or hinged. Many of them require you to remove the triple-clamp to fit them, which is a bit of a job. Hinged or split ones make life a lot easier if you just want to try it out. For example, the Panigale Clip On Bracket (129.1A 130.1A) is hinged, if you want to stay on brand. Though it won't help you with the height.
Interested to hear how you get on, as this is on my to-do list.
I have the Woodcraft 3 Inch Riser Clip-Ons on my 696 which are pretty good (and more-or-less locally built from where I live). Not as low as I'd like, but real clip-ons would require work to the front end to make them fit with good clearance.I've looked into some options for a 796, with the similar thought that the triple-clamp is quite low, so clip-ons under them would be very low.
Thanks for the note iphilrich Woodcraft do make some quality parts.I have the Woodcraft 3 Inch Riser Clip-Ons on my 696 which are pretty good (and more-or-less locally built from where I live). Not as low as I'd like, but real clip-ons would require work to the front end to make them fit with good clearance.
Phil
