1 - 15 of 15 Posts
I am switching to bar end mirrors and want to plug the hole on the lever mounts where the mirrors once screwed in on my 2002 Foggy Monster. I thought I would go to the Ace store and buy two copper flat plugs in the plumbing dept, but they are all course threaded. Then I thought of a black rubber plug, but I can't find any auto parts stores. Anyone have a suggestion?
Yup get one right-hand & one left-hand thread allen setscrew 1/4 long and lock-tight it in... [edit] metric thread[/edit]
Thanks, I will try allen setscrews. Simple and makes sense.
Thanks I will check to see if he has a set left.
Al
Discussion Starter · #10 ·
I like the plastic plugs at $1 each sounds pretty appealing. Thanks
I went to an autobody shop and got 2 plugs that fit the holes perfectly. I think the ones I used were toyota interior plugs. Best of all it was free. Autobody shops want good PR so a 50 cent item is a good investment as it may be enough to get you back in the shop when you lay the bike down or smuck up your truck in the winter.
1 - 15 of 15 Posts
