New member but been lurking for a while. I have a 2015 821, bought used about 9 months ago and only put 200 miles on it. Sunday night I was returning home when it wouldn’t shift out of 4th. Made it home, gear selector felt odd so I took left hand cover off and pulled flywheel.
found a 3/4 inch ring, not broken on dinged, a bent washer, broken return spring on gear selector, gear selector was loose, two retaining bolts were loose.
the ring was found behind the flywheel and it fits the rod holding in the gear to left of flywheel. No idea if it goes there.
did the ring cause this? Where does it go? Any chance it fell off on its own?
I found few very small bits of metal in the filter basket. Nothing that looked like the rest of spring.
suggestions?
224621
224622
F5488484-7B52-43E6-9581-D1F1FFE98C37.jpeg F669C9B2-F115-4513-9908-02B7DA098889.jpeg
