i'd never considered the v2 - w2 thing, but that's good info. i'll try to remember to put that on the site, with chris as credit for it.
i don't think the 900 heads will fit because the stud spacing is different - bigger on a 900 (same as 4v) plus the chambers will be bigger, requiring very high comp pistons to get equal or higher comp. not sure how much bigger, but bigger anyway.
they all have flat top pistons std.
you can get 42.5/37mm valves in a 750 on std seats afaik, and that would help greatly. 900 cams will go in, will/may need oversize shims or just get 900 length valves. or get 900 valves and have the heads cut down a touch as reqd.
maybe the vee two 900 torque cams will work well - the 800 has 900 valves and shorter duration cams and it makes a heap more power than a 750. these will definitely need longer inlet valves as the base circle is smaller than the std 900 cam which is smaller than the std 750 cam.
but you'll need big valve releifs in the pistons - those cams have a lot of lift at tdc.
think i'm getting off the question.
