1 - 9 of 9 Posts
I have a 2103 796, with Termis and race ECU, with high flow filter. I have modified the exhaust slightly, including relocating both cans inward, and up and under the tail a little more, I've removed the exhaust flapper valve and plugged in a DucEE. No issues with any of the installation. Tidy and works well.
My question is, is a single exhaust can enough for this engine, or do I need the dual slip-ons? I have seen mods using only one can on this model bike and other bigger engine Ducatis including the Streetfighter.
I'd like to ditch one of the slip-ons, mod the pipe and have the exhaust flow through one slip-on. In addition, if this does turn out functional, would it require Db killer removal, or would it be able to stay installed.
Thanks folks
How important are the length of exhaust pipes if doing 2-1 ? Must they be the same lenght or can one be longer?
Pro et cons?
Tnx,
Yagi
It's better if the header tubes are the same length, but not necessary.
Thank you Tim_Shady for your reply.
I am asking, because I saw bought way of mounting 2-1 exhaust, and don't know if there could anything go wrong if one tube is shorter as other? About power, compression, torgue, piston damaging?!
Regards,
Yagi
This is interesting - pls keep it going. Yagi what maker is the pre-made 2-1 exhaust?
Hey Yagi,
I've seen the SC project system in question and I think that's not street legal, it's a full titanium system without homologation. Idk why would u wanna upgrade from the Termig, but I think GPR has single exit and you can always do boomtubes. What I've been considering is actually a Zard system for the Scrambler, idk if it would fit my 796, haven't got around to find out, maybe we can research on this tgt.
-JT
Hey Yagi,
-JT
Hi Jerome,
The SC Project i linked its street legal by EU regulations. In my case I am just looking for tube manifolds (i will use something else for slip on (already have it at home), but will definitely be 2-1 (because of looks))! Now I am waiting for heatwrap to continue the project!
Regards
1 - 9 of 9 Posts
