1 - 13 of 13 Posts
C
What is the dynoed horsepower to the rear wheel of the m620? Ducati lists 60 hp on there website, but for some reason I think that is actually bhp, which if I remember is a little less then 60 hp, but pretty close. Beginnerbikes.com (which is what lead me to want a duc as much as I do) said that the Ninja 500R with 54 horsepower has 8 more then the Ducati m620.
Help?!?
C
so a carbed m750 puts down the same hp as a fuelie m620?
S
Discussion Starter #4
Yeah, give or take a few - I can tell you from experience that my 620 has noticeably less torque than my 750 had but there is sfa in it in terms of overall speed and acceleration - the 620 revs quicker and harder so on the street I think they perform about the same...someone made the comment that the 620 runs more like an inline 4 and I think they were pretty spot on - still sounds like a duke tho !
Mine was 55.8 RWHP on a Dynojet 250 with the stock mufflers. It went up to 58.9 with some cobbled slipons I made up from an old RC51 exhaust.
tell everyone its 132...then just walk away. ;D
C
Discussion Starter #7
i found the epa's website on dynoed horsepower. They list the m620ie as 44 in 2002 and 45 in 2003
C
Discussion Starter #8
it is listed as the same horsepower as the Ninja 500R from Kawasaki. I know that people have dynoed these bikes at somewhere in the low 50's high 40's range
60 sounds about right.
karen's carbed m750 dyno'ed 63.1 at the rear wheel
I've got a dyno printout claiming 69.8hp for my (carbed) '99 M750 with Staintune slipons, an open airbox lid and a FactoryPro jetkit, but the 4 other bikes that day on the same dyno all suspiciously showed about 5-10% higher than expected too (107hp for a stock '99 ZX6R? I don't _think_ so...)
big
63.2 at the rear wheel.
Many tricks you can do to "help" your dyno numbers >:D
there are a half dozen different ratings for hp and dyno operators will often fish around for the best feel good number. the type of rating is usualy on the dyno print-out SAE, DIN, STANDARD, UNCORRECTED, and another one or two I cannot remember. Usualy the numbers are higest in standard (can pick up 2-3hp on a 60hp run). the parameters as well as a presured room also smoothing can boost numbers........free hp [thumbsup]
cheers
1 - 13 of 13 Posts
