Hi Guys, I've just bought a new M1100, which after only 900km on it an oil leak has started. It's on the left hand side of the engine casing. The Ducati dealership has had a look at it 3 times and still can't find what's causing it. One suggestion is a lubricate that's been used is thinning out due to temperature of the engine when it heats up. I've heard 696's have the same problem. Can anyone shed any light on the problem if it's happened to them?
Thanks:confused:
Discussion Starter · #2 ·
Hi Guys, I've just bought a new M1100, which after only 900km on it an oil leak has started. It's on the left hand side of the engine casing. The Ducati dealership has had a look at it 3 times and still can't find what's causing it (They have also spoken to Ducati Head Office). One suggestion is a lubricate that's been used is thinning out due to temperature of the engine when it heats up. I've heard 696's have the same problem. Can anyone shed any light on the problem if it's happened to them?
Thanks :confused:
