Hey
Was just looking to ditch the stock footrest for something, mabey dropped down a little or adjustable if possible. This does also involve the support bracket to the can on either side.
Any input is awesome.
Some super expensive rear sets that are adjustable, for cheaper ones, Start here;
just follow for passenger types.
Most encounter an issue with these type of adjustable pegs. Due to simple design, it moves the feet position out, about 20mm or more.
For the rider, it means having to 'toe in' , to operate brake and gear lever. Very uncomfortable, I had some once, but ended up modifying to get them to fit in closer ie. drill new holes and grind off some metal and then found an eccentric pin for brake and gear which helped a lot.
something like this;
Moving the passenger ones down on the adjuster may impact the foot position against the muffler if you have low pipes.
I have not done it for passenger ones.
Hope this helps.
