Hello all,
I just moved to a very humid region from a highly arid environment and have noticed that my ignition cylinder is very sticky when inserting or removing my key. Also, my turn signal switch sticks in the right position as opposed to springing back to the center. I'm riding a 2004 M800i.e.
Should I use something to lubricate the key slot in the ignition? What about the turn signal? If so, what should I use? I'm not too keen on spraying some WD-40 into the recepticles, so what would you recommend?
Cordially,
Intrepid
You can try dry graphite powder in the key slot.
