guys,
I have a 1995 twin carbed M900 which developed a low speed one cylinder misfire which has now got to be more of an intermittent low speed cut out . This seems to only be evident when cold, because once warmed and at higher throttle openings ( ie at speed) it seems to run normally.
This only developed a month or so ago and seems to have occurred after I reduced the idle speed by slightly winding back the throttle stop screw between the carbs. It was idling around 1500 rpm which seemed a bit excessive, and I brought it back to around 1000 rpm
Any ideas?
Howie,
you could be right!. Both are a bother to get to and it possible that I screwed the wrong one ( no pun intended!)
