Has anyone installed a louder horn on the Monster 1100? If so, does it fit under the oil cooler shroud easily? Also, are there any models that are a direct replacement and doesn't require cutting wires?
The biggest problem is the size of aftermarket horns. The FIAMM Freeway Blaster is way too big to fit into the small space behind the oil cooler. I tried to install a FIAMM "D" horn, and it was a little too big; it was touching the heat sink attached to the plastic shroud.
