1 - 9 of 9 Posts
Brand new spares for sale. Please PM me to reserve an item. Prices exclude postage. Lots more available please PM me with specific requirements. or email mandrbarrett 'at' tiscali.co.uk
42610101A Air filter Monsters M1000 2003-2006 : M620 2002-2006 : M800 2000-2004 : M750 2002 : M900ie 2002 : S2R 2005-2006 : S4 2002 : S2R1000 2006 : S4R 2003-2006
mandrbarrett said:
Theres clearly a limit to how much you can post - I'll find another way...
No, there isn't. But, there are issues with the copy/paste feature with this new board software. Try to edit your post using the modify button to the right ------------>
Not the one at the top of the post.
See if that helps.
How bout I just ask for what you have and if you have it let me know. I want a right side panel that matches the left one for a '03 1000 Monster. I don't want the emission box bulge that the right side panel has now that I've removed it.
Discussion Starter · #9 ·
Hopefully more successful this time. This is a small selection, still cataloguing the rest, will add more soon. in the meantime PM me or email mandrbarrett 'at' tiscali.co.uk for more details or to reserve anything. All brand new.
73740112B Pair of cambelts Same as 73710061A - 748 2001 : 748S 2001 : 996 2001 £50.00
73740101B Pair of cambelts Same as 73710101A - S4R, ST4, ST4S £50.00
42610101A Air filter Monsters M1000 2003-2006 : M620 2002-2006 : M800 2000-2004 : M750 2002 : M900ie 2002 : S2R 2005-2006 : S4 2002 : S2R1000 2006 : S4R 2003-2006 £9.00
93040081A Ducati Cagiva Fork Seal 93040081A 907ie Paso Pair of Ducati / Cagiva Fork Seals. Outside diameter 52mm, fork leg diameter 40mm. For Marzocchi forks as fitted to 1992 907ie (and 906?) £15.00
93040051A Ducati Cagiva Fork Seal 93040051A 900SS Pair of Ducati / Cagiva Fork Seal. Outside diameter 55mm, fork leg diameter 41.7mm. For Marzocchi forks as fitted to 1989 900SS £15.00
85110011B Clutch star washer All dry clutch bikes inc all years of 748, 749, 996, 998, 999, 900SS, 1000SS, M900, M1000, MS2R1000, MS4, MS4R, MS4RS, ST2, ST3, ST4 £3.00
82410051A Left hand pillion footrest bracket 900SS 1997 £10.00
800070133 Mudguard fixing clamp 748, S, R 2000-2002 : 750SS 2002 : 996 2000-2001 : 998 2002-2003 : 999 2006 : 750SS 2000-2001 : 900SS 2000-2001 : ST2 2000-2003 : ST4 2000-2003 : ST4S 2002-2003 £3.00
24710021BC Alternator cover hatch Pretty much every duke ever made (too many to list) email me with your bike for confirmation £4.00
21120042A Pair exhaust valves Monster S4 2002 : ST4 2000-2003 £20.00
66049240 Engine main bearing bush Please email for details £10.00
18220062B Gearshift Drum 996 1999 : 748 1999 : ST4 1999 £40.00
82711821A Number plate light holder All 2000-2001 monsters £3.00
46665 Brake / Clutch Mastercylinder cover & gasket Monster M600 2000-2001 : M750 2001 : M620 2003-2004 : M800 2000 : MS2R 2005 : 800SS 2004-2005 £7.50
53240041A Indicator lens All post 2000 Monsters £5.00
43711071AC "desmodromico" sticker ST4S 2002-2003 : ST4S abs 2003 £4.00
46011241A Tail section vent grid All years 749 & 999 £3.00
28740402A Electrical Relay All years 748, 749, 996, 999 2006, MH900, 750SSie, ST2, ST4, ST4S £3.00
8124636 Starter Relay ? £5.00
39840011A Main Fuse ? £3.00
82911001A Support M900 1998-1999 £1.00
67038930 Battery + terminal red cap 750SS 1996, 911SS 1996 £1.00
51410172A Starter motor cable 748, 996, 999, ST2, ST4, MH900e £3.00
51410141A Starter motor cable ? £3.00
38940101A 30A main blade fuse Pretty much every duke ever made (too many to list) email me with your bike for confirmation £0.50
82110091B Set of 5 Cush drive pins, (double sided swingarm models) All double sided swingarm models inc 749, 999, 800SS, 900SS, 1000SS, Monsters M600, M750, M900, M1000, ST2, ST3, ST4, Sportclassic, Paul Smart £10.00
70010381A Set of two rubber instrument mounting blocks All Monsters with twin round clocks. M1000 2003-2005 : M620 2003-2005 : M800 2004 : M750 2002 : M900 2001 : S2R : S2R1000 : S4R £4.00
77911951A Set of two headlight fairing mounting screws All monsters with headlight fairing / screen M620, M800, M900, M1000, S2R, S2R1000, S4, S4R £3.00
705462125 Set of  4 Cylinder head Intake Studs M600 2000-2001 : M750 2000-2001 : SS750 2001 £5.00
75549033 Set of 7 Cylinder studs ? £10.00
76610012D Set of 4 Cylinder studs 916 1996, plus others?? £15.00
76610012B Set of 3 Cylinder studs 748 2001 : 748R 2000 : 999 - 2006 : M1000 2003-2005 : M900ie 2000 : MH900e 2000-2001 : SS900ie 2000 : ST2 2000-2003 £15.00
77110031A Rear suspension linkage rocker bolt 748 2000-2001 : 748R 2000-2001 : 998 2004 : 999 2004-2006 £5.00
11710301A Gear linkage rod 150mm long, right & left hand M6 threads ? £7.50
75011081A Chain tensioner nut 749 & 999 all £2.50
1 - 9 of 9 Posts
