I found this info on ebay for finding your code maybe it will help, if so reply and let me know where you found the code.
Key codes may be obtained from various places; this varies a lot depending on the age, make and model of the vehicle.
Remember that a key code is specific to your vehicle, so any numbers you find that are part of the manufacturing process for all the locks produced will not be your individual code.
These are the usual possibilities for finding key codes-
EASIEST
- in the original owner's manual (hand written or maybe stamped, or an adhesive sticker)
- on a tag that came with the original keys or a vehicle identification card
- on a plaque inside the glovebox door or elsewhere
- on the outside rim of lock keyways
- stamped or engraved on the original keys (note: not raised lettering, that's probably the key blank type not the individual lock/key code. However provide us with all information you find, it may help).
NOT SO EASY
- under a cover on the outside rim of lock keyways
- stamped on lock housing or body (may need to remove trim to access locks)
- on a paper decal or similar attached to, or near, the lock
GETTING HARDER
- stamped on lock cylinder (requires disassembly of lock)
FROM THE MANUFACTURER'S DATABASE
- refer your vehicle VIN (chassis number) to the manufacturer's database which will tell you the code(s) for the vehicle's original locks. Consult a current authorized dealer to see if this service is available for your make and model.
A fee may be payable (and the dealer may insist on providing a key).
For many British classics, the British Motor Industry Heritage Trust offers this service. Expect to pay a fee, see here (this link is outside our website) or email Richard Bacchus
Note: code-cut keys can be cut correctly only if the code information supplied to us is correct.
