Anyone have this happen? The front brake lever wiggles up and down quite a bit compared to the clutch lever. Looking at the way it works, there's a pin with an e clip on the underside (to allow the lever adjustment with the 4 position wheel) and a bolt that holds it to the master cylinder. Its loose in both places. I tried to tighten up the bolt, but its already as tight as its going to get. Whats the fix for this, washer shims? Id like to know why its like that. Bike is new to me 00m900, 2500 miles.
Kevin
Kevin
