What do you mean by load tested?
Whats the voltage on the batt while your pressing the starter button?
No, I was figuring you had a volt meeter, which is why I asked about the load test.GregorMac said:Don't know; is that on your gauges?
I'm not too sure exactly what that "load test" was measuring, but if it was cold cranking amps, it's _way_ low - the battery for my '99 M750 is a Yuasa YT12B and it's specs say it ought to put out 125 Amps...GregorMac said:Is that too low? Will a day or so on a battery-tender get it back in shape? What's the bottom end? Bikey no start. Is this amperage insufficient? I'm also investigating starter solenoid.
Well, the dude at Schuck's said 'amps', and I'm not Einstein when it comes to bike electrics. The bike isn't starting; that's my problem. Knowing the battery is good, now has me looking at the starter solenoid. hmmm...I saw in one thread where someone said to use a piece of heavy-gauge wire across the leads of the solenoid. How heavy?Mdriver said:A load tester measures the available voltage under a load.
I read it as 11.86 VOLTS as in under load your bat drops from 12.4 down to 11.86 VOLTS
GregorMac, is the bike cranking slowly or is there no power at all?
4 or 6 gauge. same as the battery leads. A screwdriver works.GregorMac said:Well, the dude at Schuck's said 'amps', and I'm not Einstein when it comes to bike electrics. The bike isn't starting; that's my problem. Knowing the battery is good, now has me looking at the starter solenoid. hmmm...I saw in one thread where someone said to use a piece of heavy-gauge wire across the leads of the solenoid. How heavy?
Hmm...good point. However, what else is in line to F things up? Obviously dirty connections. Anything else?Mdriver said:Keep in mind, if the bike starts when jumping between the 2 terminals on the starter solenoid doesn't prove that the solenoid is bad. It just proves that the starter and the battery are good.
A short in the lines from the solenoid to the starter could be a problem...GregorMac said:Hmm...good point. However, what else is in line to F things up? Obviously dirty connections. Anything else?
Possible, but unlikely, a short there would generate quite a lot of smoke - the recommended batteries will dump well over 100A into a dead short - you'd know about _that_ soon enough... More likely would be a bad connection at either the bolt on terminal of the solenoid or at the starter... It's also possibly the brushes or commutator in the starter, but again, unlikely - I've got 110k miles on mine and it's still got the original brushes in it - unless you've got high mileage and do lots of very short trips (implying many more starts than usual) I doubt it'd be that.NAKID said:A short in the lines from the solenoid to the starter could be a problem...
