1 - 14 of 14 Posts
bikes don't have windows!....at least most bikes I've seen [cheeky]
you talking about the oil sight glass on the left side?
i have one on the brake side and its full the clutch side with the window is low? whats this mean?
so its supposed to be emtpy? i was riding and all the sudden the oil light flashed and the bike shut off.... but i started it right up and no light came on when i immediately restarted
Did you check the oil afterward?
The oil window is on the right side of the bike beside the clutch
left side window flywheel. when the bike is running you can see it spinning. right side glass oil sight. on side stand between two marks. too much oil and the motor could spit oil back up into the airbox.
the oil should show between the two marks with the bike upright, not on the sidestand...
1 - 14 of 14 Posts
