I have a 2001 Ducati Monster 600 with carbs. I cleaned and rebuilt the carbs when I first got it (about 6 months ago).
Rides OK, but I am noticing two things: it fouls up spark plugs pretty quick and it actually doesn't increase HP/Torque when I go wide open throttle under load (say going up a hill).
I put jets in it that were modestly larger than factory spec because it has a full exhaust on it, but since then it's dawned on me that the air in is all stock.
So the factory jets are 37.5, 70 and 132.5 but I think I have 40, 70 and 140 maybe? I left the needle settings pretty much as is etc.
So, I assume the black foiling of the sparks is because it's too rich (this takes a few months of riding to accomplish, but it will get to the point where it won't start unless I clean or replaced the plugs), and is especially rapid and bad if I use the choke for extended warm ups (below 50F).
But... is running too rich and/or having too large a main jet the reason that is kinda bogs down under WOT?
Example: second gear, 40MPH at 5000rpm climbing a moderate incline. Twist the throttle wide open, the bike climbs to 6000rpm and gets a little more oomph, but then cannot really rev higher nor achieve more power/speed. Supposedly peak torque for the bike is around 6000rpm and peak HP is around 8000rpm, but I don't feel much of anything more when I get the bike above 6000rpm, especially if its on an incline.
To be fair, the bike only has like 50hp and 35lb/ft so is this just what a wimpy bike feels like? Or do I need to retune the carbs for better performance?
