allright do you have to mess with jetting when you put on a kn airfilter? is there any adventage to going with a kn airfilter on a carbed '01 750.
1. yes. even more so if you mod the airbox by removing snorkels or cutting the topallright do you have to mess with jetting when you put on a kn airfilter? is there any adventage to going with a kn airfilter on a carbed '01 750.
I'll be doing it this weekend. Can you elaborate?there is a little trick to doing it, i will try to elaborate if you decide to do it.
I'm not so convinced... I seem to remember a discussion on the list a long time back where someone claimed that a K&N didn't flow any better than the (apparently very well designed) stock Ducati paper filter, at least while the paper filter is new/clean. I can't track it down in my archives, but google found this for me:dicatistajoe wrote:
2. only if you change the jetting too
the above is correct. opening the airbox requires jetting. opening the airbox also requires a KN or similar filter. the paper filter won't like rain.I'm not so convinced... I seem to remember a discussion on the list a long time back where someone claimed that a K&N didn't flow any better than the (apparently very well designed) stock Ducati paper filter, at least while the paper filter is new/clean. I can't track it down in my archives, but google found this for me:
http://www.fuelinmoto.com.au/fimfaq.html#q6
I think the main advantage of the K&N is that its cleanable/reuseable - thats why I put mine on, it cost me about 20% more than a new paper one from the local Ducati ppl, and its (hopefully) that last one I'll ever need to buy for it.
If you're losing the snorkel or modding the airbox lid, you'll probably need to re-jet, but if you're just swapping out the filter for a reuseabe K&N, I'd be _very_ surprised if it made enough difference to bother tweaking the carbs...
If you've got a local friendly dyno guy with an exhaust gas probe, see if you can convinve him to let you do a before/after run - I'd _love_ to find out if I'm right or wrong...
big
Yep, I put the K&N in at the 10,000km service, and ran it like that for the next 50,000km. Then I put Staintune cans on and cut open the airbox lid and rejetted it.thanks for that post, thats what i wanted to know. yeah i am not doing it for performane but maintnance as well. so you did no jetting with yours?
Street use:
Street use:
