    i'm wiring a haress to a 2000 900ie motor and I've put everything in place, but the first time I went to start it, the starter turned over like it should but nothing fired. Soon after this my fuel pump stops and the starter won't turn over right. Oddly enough, the turn signal 7.5A fuse has blown..although my turn signals aren't even hooked up yet and im nearly positive I haven't mistaken my brake lights or turn signal wires for something else. But, I've confirmed that the fuel pump will keep blowing this fuse.
    Aside from this obvious problem, my starter now won't crank my engine like it should. Instead it blips or just turns with full juice for what seems like half a turn and then cuts out. It won't be ready to do this again for a couple seconds until I hear a relay click and I can make the starter blip again. Does this make any sense??
