K&N Grease?
809 Views 8 Replies 5 Participants Last post by  ducpainter
This summer I replaced my air filter with a K&N filter. The filter came with a small tube of grease. The instructions said to grease the permiter of the filter. I did.
Is this necessary, does the filter not fit well enough to seal?
Has anyone not applied the grease?
1 - 9 of 9 Posts
That Nice Guy Beck said:
i use it for my dj booth
I have to ask, where?
I rememeber reading on a VW forum that SuperLube
Super Lube is what was provided by K&N to use.
It looks like a tight fit between the filter and the air box. Why should I apply this lube. It hasn't made a mess to date but I'm sure someday the grease will work it's way to where I don't want it.
I believe the grease closes any little gaps/imperfections between the filter and the air box and stops any dirt from entering the filter via the seal by providing a tighter fit. I don't think you need a whole lot of grease, just a thin coat.
Again, I'm just guessing.
But it does remind me of a joke involving a penguin and his car...
FP
The 'structions say it's to seal near the screw recesses that hold the plastic filter support to the airbox. I used it. I even added a little in the subsequent airbox removals to get the jetting right.
There's still some junk in the airbox. I know a couple of knowledgeable people that don't care for K&N filters because of that. If I go to a more effective filter I'll probably have to re-jet, and I'm too lazy.
I have the same holy air box cover as you and ride in the rain with the OEM paper filter without problems. I think BCM likes BMC filters for the reason you mentioned. I doubt the filter itself will require re jetting since the big change is opening the air box.
When I see one for the 25 or 30 dollars I paid for the K&N I'll try it. [thumbsup]
Bruce was one of the knowledgeable ones I referred to.
1 - 9 of 9 Posts
