1 - 12 of 12 Posts
okay guys, I am pretty mechanically inclined, and I have plenty of tools, so do you think I should install my new blue anodized pressure plate and stainless bolts and springs myself? Should I have have my mechanic do it? Is there anything i have to worry about? Are there a million small pieces behind that plate besides the cluth plate? I am psyched about this piece. I already have a semi open clutch cover and can't wait to see how it looks!!!
Even if you are only moderately mechanically inclined...it is a breeze...Grab your Allen wrenches and have at it. It is an intuitive job....
Post pix when done.
Without a doubt, don't hesitate to do it yourself. If you wear glasses, you could smear vasiline over them and be able to do the job!
blue..........that's one color I don't see often. I wanted a blue S4, but I don't think they made a blue. Anodized blue is a slick color [thumbsup] C'mon, where's the pics? wanna see. did you get red spring caps? that's a cool combo. It's snowing over here and I'm bored, can't ya tell?. I'm getting excited over someone else's bike! make sure you have some loc-tite for your spring bolts and don't overtighten.
MM
MM
I appreciate your excitement dude. My Bike is yellow as you can see in the pic to the left, all my riding gear is blue so thats why I went with the blue plate, and the springs and bolts are just polished stainless.....project should be done this weekend if I am not already predisposed by my better half......
I've read in the past that the use of loctite is not necessary as the springs supply enough force to keep the bolts from backing out. I could be wrong here though.
You could upgrade the spring post bolts with titanium bits. I just did that, I find titanium funny, because the weight is so light I feel like somebody is pulling a fast one on me and substituting shiny plastic bolts.
yes you are correct, I wouldn't use loctite on those bolts
I may be a wuss, but I recommend getting a torque wretch and tightening the bolts back to spec. The 3 manuals I have for my bike all had different torque values, so I still had to wing it a little.
for the spring retention bolts? You could use a torque wrench, but there's a high chance of torquing too much and shearing the bolt head off or even worse, breaking the leg off the clutch drum (there's more than one person who's done this :-X) The torque is 10 Nm or what I call, snug. The pressure exerted by the spring will prevent the bolt from backing out like someone said above.
1 - 12 of 12 Posts
