Re: Is there a trick for tire changing w/out a sta
Well, I built a stand out of 3/4" plywood (for the base) and 4x4s that I could set the bottom of the forks on, but...
YOU MUST BE VERY CAREFULL!! this is very unstable, I put the axle back through the forks to keep the legs from twisting after I pulled the wheel. I also used a cinderblock on each side of the bike in case it wanted to fall over. This was a VERY sketchy way to leave the bike. I wouldnt even open the garage cause I was afraid a breeze would blow it over. It took me about 15min. to make my little stand and I got my new front rotors on but it was scary.
