1 - 18 of 18 Posts
· Premium Member
Hello all!!!
Here are some few steps i made to install a new pressure plate(Ducati Performance) and Clutch cover(Rizoma)....
In my S2R 1000....
That´s too easy:
Hope you enjoy this mod!!! Cheers ;)
· Banned
Thanks for the post. Picture threads are awesome. It's now in the FAQs.[thumbsup] Check it out.
P.S. Are those pictures hosted in a location where they are permanent? I don't want them to disappear after a while since the thread is linked to the FAQs. If they're not, can you upload them to the DML and then link to them? Thanks.
· Registered
· Premium Member
I couldn't see an alignment mark on the DP plate, didn't notice one on the SpeedyMoto plate I just installed. My first ride with the new plate and cover today resulted in the pressure plate failing to clamp after 15 miles or so. Started out as a gradual vague engagement and progressed to no clutch at all, but the lever feel remained constant.
I pulled the clutch apart and inspected the plate stack, pressure plate, springs, push-rod to bearing contact, etc. Only thing I could assess was there wasn't satisfactory grease in the push-rod to pressure plate bearing area and the gradual build up of heat and possible tighter clearance with the new PP bearing cause the plate to hang on the push-rod. Cleaned things off and applied some high temp/pressure grease and everything seems fine.
Clutch now holds 5th gear full-throttle run and quick short-shift 1-2-3 gear acceleration runs, and engagement smoothed out.
(This is my first Duc so I'm not in tune with the politically correct wrenching procedure yet)
Could I have missed an alignment procedure?
I might suggest adding application of a small amount of quality hi-temp grease to that connection in your excellent post.
· Premium Member
Hello!
Yes the DP plate have a mark to alignment procedure!!!
It´s kind hard to see it but...
It´s a litle dot :
I didn´t put any grease in it(mine allready have), it was just a 15min operation. [thumbsup]
Cheers, Pedro Saro
· Premium Member
Sieg said:
<snip>I couldn't see an alignment mark on the DP plate, didn't notice one on the SpeedyMoto plate I just installed.
The Speedymoto plate does have a mark, it's a small line on one of the holes. In this picture it's at 11 o'clock.
Sieg said:
Just pulled the plate again and there was aligment references.
It appears you found it, but I thought I'd post this anyway for the rest.
· Registered
The marks align the spline teeth for boss to hole concentricity. One aligned position is concentric, the other 5 are not. There may be one unaligned position which is vary close but non-concentric which will allow you to assemble, but the springs will bind. Be careful and make sure the marks/splines align properly. No not over torque the socket head cap screws, use a torque wrench and specified torque value.
1 - 18 of 18 Posts
