Generally do you cut/melt the little plastic nubs off or drill the new clip-ons? I don't wanna melt them away if they're critical for preventing the controls from slipping and rotating around the bar.
They are there primarily to locate the gear during assembly to save time and ensure the same placement on each build. No big deal to dremel them off. I would not melt them......there is a fine line between melting and destroying/burning/fire. Personally I would drill the clip ons.
You can dremel them off, if they rotate wrap a turn of insulation tape on the bar.
i drilled new holes in my woodcrafts to mount the controls. used them for the first time today. loving them so far. i will say it was a real pain to make everything clear. had to reroute plenty of lines. still waiting on a headlight part to see if everything goes together properly but im a lil skeptic....
