I have an "aiming" issue. I can't seem to get the right side to line up very well. The part where the can meets the pipe seems to kink out a bit and I can't seem to get it to just line up straight. Anybody have problems with installing these things?
Not 100% sure on this, but it might be due to those big aluminum doughnut spacers on the rear sets. If you've puleld off your smog can you might need to fill a bit of space on that side to even thigns up again for the exhaust orientation to be correct from left to right,DarkJedi said:I have an "aiming" issue. I can't seem to get the right side to line up very well. The part where the can meets the pipe seems to kink out a bit and I can't seem to get it to just line up straight. Anybody have problems with installing these things?
