I have the KlavKarr 210 (I think it's called 'expert').
I also use it quite a bit on my Subaru and have used it to help a friend out diagnosing some problems with his Honda.
So I would't hesitate to recommend.
However you might want to be aware of some compatibility issues. There are various versions of the ELM chip that is used in these dongles for OBD2.
Early ones used a chip from a company called "ELM" and had a protocol/interface version number up to 1.4 or 1.5 IIRC.
These are very widely supported by lots of open-source software and freeware.
Newer dongles seem to have higher version numbers, e.g. 2.0 and 2.1. Not all of these are supported by older software.
Just so you are of the combinations that work/don't work - here is what I had last time I tried:
Scanner | Software | Combatability |
KlavKarr 210 | EOBD-Facile | Works OK |
KlavKarr 210 | M3C9 | Doesn't work |
OBD2 ELM 327 V1.4 (from Amazon) | EOBD-Facile | Works OK |
OBD2 ELM 327 V1.4 (from Amazon) | M3C9 | Works OK |
Maybe others can add/comment...
I was going to buy OBDSTAR iScan Fit for Ducati OBD2 Scanner Diagnostic Tool IMMO Coding. ISCAN for DUCATI is a portable tablet which has super performance and industrial appearance design specialized for DUCATI. It is a new generation of intelligent motorcycle diagnostic equipment tailored for customers. Based on RK3128 quad-core processor and equipped with a 5.0-inch capacitive touch screen, brings customer professional diagnosis experience. 1. Support DUCATI diagnosis and k-ey Coding
2. New android 5.1.1 operation system;
3. Simple and intuitive menu guidance allows you to quickly understand how to use the tablet;
4. Provide complete diagnostic functions including code reading, code clearing, data flow, action test, setting, coding etc;
5. Menu selection is more convenient and quick;
6. Record and play back real-time data streams, quickly and accurately locate sensor and component faults;
7. Wi-Fi connection to the internet, one-click software upgrade;
8. One-click remote help function, OBDSTAR technical staff offer remote assistance.
9. Lightweight and portable, your motorcycle repair helper.
10. Multi-language: English, Spanish, Portuguese, French, German, Italian, Polish, Russian,Turkish, Indonesian, Persian and Korean
Advanced function:
1. The first fault guidance, help data, technical bulletin, diag socket, etc. help you diagnose accurately and efficiently;
2. Diversified data stream display modes such as text, waveform diagram and instrument diagram, allowing you to easily analyze faults;
3. Automatic scanning, automatic VIN recognition, control module coding, E-C-U setting, instrument coding, tire pressure monitoring system, maintenance light reset, CO adjustment, idle speed adjustment, A/F value reset, ABS control unit setting, EOL mode, transmission memory reset, clear computer memory etc
It runs $500+ made in China comes with tablet- main cable-Ducati plug. They're on eBay. I'm new to this. I was going to buy it but wanted some advice first. What do you think???? Thanks
