Hi all,
Am in the process of deciding how i'm going to remedy a '95 model 900 cracked crankcase problem. :'(
One of my thoughts was widening my possible engine choices.
Has anyone tried to put an injected motor in a carbed bike. I was going to keep the carbs.
The ignition will have to be changed with what i presume to be the injected ECU and part of its loom.
Can the carbed ignition be transplanted into the injected motor?
Is that the extent of the differences?
Thanks in advance
What yr./size injected engine are you looking @ swapping into your '95?
If you were to try & run the injection, there is a frame tube in your way which will need cutting & relocating. I know this, as I've injected my '99 M750CR.
Looking at a 2000 model injected 900 motor, and was tossing up between the carbs and the injection.
Is the extra bracing only on the 750 frame?
I had a look at the parts manual for the 2000 model, i'll have to wait to get home to look at my frame.
Is it one of the diagonal tubes that run across the frame?
Seems strange that they had more bracing in the earlier frame? Or was it that they had to move the bracing for the injectors.
