1 - 20 of 110 Posts
Discussion Starter #7
I went with Rad Guard AU. and will install it tonight. It's pretty beefy and feels better then my cox guard I had for my R1. ImageUploadedByMO Free1405622315.565004.jpg ImageUploadedByMO Free1405622325.685980.jpg ImageUploadedByMO Free1405622335.053702.jpg
Discussion Starter #10
Looks good. I might do this. Do you have a waterproof cars for the smart phone am assuming you mount there?
I don't have a waterproof case for the phone and well get one later one.
Discussion Starter #13
I went with RadGuard since Evotech was out of stock. Fitting was good and it super beefy. Ducati is a dbag since they use loctite red on plastic trim screws.
http://www.radguard.com.au/products/ducati-monster-1200s-2014-radiator-guard.html
View attachment 147825 View attachment 147833 View attachment 147841
Looks great. I might get the polished metal version as it wont show rock chips on the paint like the back will. Not sure.
Discussion Starter #16
Discussion Starter #17
I used a USB to sae plug.
My dealer installed a trickle charger lead on all their bikes. If you want to do that you will need to dermel a notch in the cover for the lead or get the Ducati battery tender and it have the dda to sae plug. Plus if you use the Ducati battery tender kit it will look a lot clean then the reg. battery tender. All the Ducati stuff is under the seat.
Plus the sae into the trickle charger lead
Run the USB to the front of the bike and to where every you want. I recommend lifting the tank up and hind it under the tank. I'm going to clean up my install when I stop being lazy.
ImageUploadedByMO Free1407503116.477378.jpg ImageUploadedByMO Free1407503130.823026.jpg
1 - 20 of 110 Posts
