Quick question. I bought a project 2003 620 that won't crank over. Key turns, gauges deflect, LED flashes, check engine light is on. But the engine doesn't crank. I checked ohms at kill switch and is fine. My question does the immobilizer allow the engine to crank over or does it stop it dead?
Stops it dead. It won't crank if the immobilizer is active. I think the LED goes on solid also.
Thanks! that's what I was thinking. I wired in 12v to the solenoid and it cranked so I assumed it was the immobilizer after I checked the other stuff. Thanks again!
