M
Any one know where the idle adjuster screw is on a 600. Some one was nice enough to tell me where it was on an S4, but it ain't in the same place on the 600. In fact, two of us coldn't find it in 20 minuits of searching. Ugh. The thing needs new plugs too. Those hang right off the side, real wasy to find. Grrrr....
ken
T
Discussion Starter #2
This is impossible to describe. The idle adjust is a phillips screw located under the tank (at the carb linkage). It is adjusted with a 12" (minimum) phillips #2 approaching from the front tire. The easiest way to find it is to look under the tank with a flashlight while twisting the throttle. With your head near the front tire and looking under the tank, you will see the screw on the eccentric that adjusts the idle - it wil be evident (However, do be cautious as the low idle circuit adjustment is near).
